Siemens - Ysio Max
by Siemens
The most direct way to the image.
Siemens' high-end digital radiography (DR) system Ysio Max offers multiple advances enabling you to achieve the best image quality in the shortest amount of time possible with your system. It lets you enjoy the proactive support of MAX assistance and the most comprehensive imaging technology of MAX detection.
FORUMSView All (5)
-MASEANEZ
Fri Feb 27 2026
Error 2005/243
Does anyone know what this error code is?
Equipment: Siemens Ysio
-olto
Wed Nov 09 2022
Err 558 / 17: DMG (blue LED indicator needs to be disengaged. If not possible call servic
Seems everything work fine, but this message are a bit annoynig.Reply
-Adel100006950
Sat Dec 12 2020
Siemens YSIO Service Manual
Where may I find YSIO service manualReply
[list]      [*] Experience MAXalign – Get it right with the first shot.      [*] Aim FAST – Takes the fastest and safest way.      [*] Feel MAX wi-D – Lighter. Thinner. Faster.      [/list]
Weight3 kg
Table       Max. patient weight: 300 kg / 660 Ibs      Table height: 52 cm to 95 cm / 21” to 37”      Max. patient coverage: 190 cm / 75”            MAX wi-D detector       Dimensions (detector area): 35 cm x 43 cm / 14” x 17”      Weight: 3 kg / 6.6 Ibs      Thickness: 19 mm / 0.7”      Post processing: MAX image quality with DiamondView Plus            MAX mini detector       Dimensions (detector area): 24 cm x 30 cm / 10” x 14”      Weight: 1.6 kg / 3.5 Ibs      Thickness: 16 mm / 0.6”      Post processing: MAX image quality with DiamondView Plus            MAX static detector       Dimensions: 43 cm x 43 cm / 17” x 17”      Post processing: MAX image quality with DiamondView Plus            Detector integration       Free exposures: Unique MAXalign – displays detector angle and enables perfect alignment of tube and detector      Detector sharing: MAXswap – 1-click registration and sharing between Ysio Max, Luminos dRF Max, Luminos Agile Max      Detector configurations: optimized for 1, 2, 3 and 4 detectors            System automation       Aim FAST: Unique fully automated, simultaneously movement in 6 axes to enable the fastest and safest way to the position you need      Organ programs: Over 1,000 user-defined preset system positions for easy standardization and high throughput      SmartOrtho: Fully automated tilting technique for long leg and full spine imaging, up to 4 images            Imaging system      User interface: 1 user experience throughout Siemens radiography, fluoroscopy and urology portfolio      Image storage: 10,000 radiographic images
