Siemens - Multimobil 5C
by Siemens
Mobile C-Arm
The mobile C-arm MULTIMOBIL 5C provides the optimum solution of today's clinical requirements. It is ideally suited for entry level surgery in many application fields such as orthopedics, trauma surgery, general surgery.
FORUMSView All (3)
-Pbvannur
Sun Jan 09 2022
Replacement of multi-core cale
Sir, kindly send me the instructions how to replace the siemens multimobil 5 c, multi-core cable.Reply
-vidadi
Mon Nov 01 2021
Service Manual version 8.0
Good afternoon. Please help with Siemens Multimobil 5C - Service Manual version 8.0 Reply
-GVVPRASAD
Wed Jul 04 2018
latral image distrubence
Siemens C ARM Multi Mobile 5E problem is image distrubence found problem in cable from main unit to camera unit please send any one help cable connection circuit diagramme Reply
  • Orbital movement125° (-35° to +90°)
  • Angulation±190°
  • Horizontal movement20 cm (7.9)
  • Swivel range±12.5°
  • Vertical Travel40 cm (15.7)
  • Fluoroscopy voltage: 40 kV to 110 kV
  • Focal spot sizes, minimal value: 0.5/1.5 mm
  • Selection: automatic selection of focal spot for fluoroscopy and radiography
  • Thermal protection: auto cut-off of fluoroscopy/radiography in case of tube head temperature exceeding 60 °C
  • Collimator system: motorized iris collimator for concentric collimation
  • X-ray image intensifier
  • Nominal diameter: 23 cm
  • Image rotation: endless clockwise and anti clockwise
  • mage reversal: left/right and top/bottom
  • Displays: 2 x 15 black and white TFT displays for live image and
  • Power requirement: maximum 3.5 kVA
  • Cassette holder: standard
  • Interface to external recording device: optional
