Siemens - Acuson S2000
by Siemens
The premium-performance ACUSON S2000 Cardiovascular (CV) Ultrasound System is equipped with everything users need to confidently diagnose.
Built on next-generation acoustic and innovative applications, the ACUSON S2000 CV system supports a broad bandwidth of imaging frequencies, providing never-before-seen detail and full cardiovascular functionality in adult, pediatric, vascular and operating room environments. Further, the system’s open architecture and transducer compatibility across multiple Siemens ACUSON ultrasound platforms provide extraordinary value and investment protection
0RepliesFri Nov 14 2025 | Heart rate calculation error I recently had to reload the software on an Acuson S2000. Since then, the M-mode and PW-mode heart rate calculations are wrong by a factor of 3. Sometimes if I adjust the sweep speed it is then correct, and sometimes that does not fix it. Normal I would set the curser from one systole to the next. But now, instead of a rate of 130, it reads 400ish. If I set the cursor from one systole to the 3rd down the line, then the heart rate is correct. Any ideas on how to correct this? Reply |
1ReplyThu Dec 28 2023 | S2000 caed cage access. Our system stopped booting after transport. I have re-seated the connections to the power supply but would also like to do the same with the card cage. Can anyone telll me the best way to access the cards so I can make sure they are seated properly. Reply |
3RepliesWed Nov 08 2023 | Siemens - Acuson S2000 does not turn on, Siemens - Acuson S2000 does not turn on, the green light on the power button flashes, the power supply and battery ok LEDs are on on the power supply. The battery has the correct voltages, but the computer does not turn on nor does the equipment. Any suggestions please, if you can help me with the service manual that would be perfect. Reply |
