CareFusion - Alaris PC 8015
by CareFusion
Refurbished Carefusion Alaris Medley Module PCU 8015 Point-of-Care Unit is the core of the Alaris System, which provides a common user interface for programming the infusion and monitoring modules, helping to reduce complexity at the point of care. This central "brain" allows other modules to be connected including LVP (Infusion Set), SPO2, NIBP, ETCO2, Syringe and PCA
1ReplyWed Aug 27 2025 | Maintenance on the batteries To maintain the batteries on the Alaris 8015 pumps should they be pumped in all the time? Equipment: Alaris PC IV pumps 8015 Reply |
3RepliesTue Jul 15 2025 | DC Power Issue with Alaris PC Has anyone encountered this... I have a unit that will not work on DC power. As soon as the unit is unplugged, it powers down immediately and begins to beep. I've replaced the battery, power cord, and battery connector harness assy. It's noteworthy to say, unit appears as if it's charging, but as soon as I unplug device it dies. If I plug device back up and power it on, it begins to show the low battery 5 min notification all over again. I performed a battery conditioning test, and it points towards a bad battery. However the batteries are good. Any feedback is appreciated. Equipment: Alaris PC 8015 Reply |
5RepliesTue Jun 20 2023 | Alaris 8015 PC not turning on Whenever I press the System On key, the red arrow starts blinking and the unit beeps until i press the System on key again. I've tried holding the tamper to go into maintenance mode and that doesn't work either. It has a battery from this year. I charged it overnight and the issue continues this morning. Not sure if others have ran into this or what else to try. Reply |
Infusion pumps are invasive pieces of medical equipment that work to save lives through preventing dehydration, and also aid in the continual release of medication.
