Awareness Technology - Stat Fax 2100
Microplate reader
The Awareness Technology Stat Fax 2100 Microplate Reader is a compact, fully automatic reading unit. With its biochromatic optics, the reader is most ideal for in-vitro diagnostic use, computing the results of endpoint colorimetric assays. A versatile unit, the Stat Fax 2100 can measure monochromatically or bichromatically. The reader also accepts many single column microstrips up to 12 wells in length, as well as break-apart wells in both flat- and round bottoms. After positioning the carrier to the desired row, the system automatically positions the strips, reads absorbances, calculates concentrations, and prints results. The integrated thermal graphics printer also allows the system to plot standard curves. Additionally, the Stat Fax 2100 instrument offers pre-programmed modes for performing the most commonly used calculations, multiple convenience features, and user programmable memory to further facilitate testing. Each mode comes with a step-by-step prompting, reducing error and streamlining operation for the user. User-programmable memory also allows the operator to store test protocols, recall tests by number, and delete unwanted tests from a user-generated test menu. The convenient Stat Fax 2100 reader combines automatic blanking options with the location indication of positive and negative controls. Moreover, the user can enter control acceptance criteria for automatic comparisons, and edit out discrepant duplicates with automatic reread and recalculation.
FORUMSView All (8)
0Replies4 days ago | Stat Fax 2100 Buenos días. por favor podría ayudarme con el manual del Stat Fax 2100 en español. no he podido calibrar unas pruebas hormonales y necesito hacerlo urgentemente, gracias Good morning. Please could you help me with the Stat Fax 2100 manual in Spanish. I have not been able to calibrate some hormonal tests and I need to do it urgently, thank you Reply |
0Replies4 months ago | service manual filter error Equipment: Stat Fax - 2100 Reply |
0Replies2 years ago | Stat fax 2100- PC conexion Does anyone know if it is possible to receive stat fax data to a Windows 11 computer? Also, is it posible to use a cable with one end being a DB-9P and the other an USB port?Reply |
- Automatic sample transportation
- Bichromatic optics
- Easy to use with step-by-step prompting
- Automatic calculations and on-board graphics printing
- Large, non-volatile memory with storage for more than 36 user-entered tests
