Baxter - Gambro Phoenix System
by Baxter
Hemodialysis Unit
Designed with a unique protective blood module, Phoenix system eliminates the risk of cross-contamination between patients caused by transducer protector contamination. The low-volume design of the Gambro Cartridge™ Blood Set also offers optimal biocompatibility, while the combined use of BiCart® Cartridge and Diaclear® Ultrafilter reduces bacteria and endotoxins, resulting in fewer dialysis related problems for your patients. The innovative Phoenix® dialysis system has set a new standard in patient safety and operational efficiencies.
0RepliesSat Aug 02 2025 | Hemodialysis fluid removal Can you tell me where is shows exactly fluid removal? My daughter gettin hemodialysis 3 times a week and i don’t want to take from her fluid.Yesterday the nurse practitioner said they won’t take but i need to sign the declining form what they didn’t give me to sign it and i think the fluid was removed fro her 0.300.On target Loss shows 0.300 kg Tot.Fluid Removed 0.300. They explained to me that numbers not good every time will show different and they will flush the tube end off dialysis. That not was true what the nurse practitioner said right? The other day on Wednesday they took out 0.400. Thank you! Reply |
0RepliesSun Nov 05 2023 | disinfecting Can you please tell me how to disinfect the who port Equipment: Baxter - Gambro Phoenix System Reply |
0RepliesSun Feb 19 2023 | provider for the caribbean Hello, I need a supplier of parts and blood lines for the Caribbean (Dominican Republic) I have 13 Gambro machines that a customer boughtReply |
| Height | 56.7 in without IV pole |
| Length | 27.9 in |
| Weight | 364 lbs |
| Width | 24 in |
