Berchtold - Chromophare E 558
by Berchtold
High tech meets high performance.
BERCHTOLD’s CHROMOPHARE E 558 uses a cutting-edge LED light source to create bright light, with very little waste heat. Its compact and slim head design is ideal for     low ceilings, and makes it the ideal companion light to BERCHTOLD’s larger E 778. The option to change color temperature to match surgeon preference is another unique user-focused feature. Easy operation, freedom from bulb changes, a multitude of options, and the ability to combine with other lights, flat panels, and equipment booms create a product that is optimized for the entire surgical team.
-LAKH
Tue Jan 05 2021
ORDER ELECTRIC BOARD
Hello I need to order the board C1-324-3 V1122-022 001 of BERCHTOLD CHROMOPHARE E558 LED MOBILE; Best regards Reply
-Mmonzon
Tue Apr 23 2013
Delivery to Spain
Dear sirs,
We are interested in the Cromophare E558, we are from Spain and we don't know if we have to contact a dealer in our country or we have to speak directly to you.
Could you let us know?
Thank you
[list]    [*] Efficient LED light source for cool operation     [*] Smooth consistent illumination across the field     [*] Optional color-temperature adjustment from 3600K to 5000K     [*] Ultra long-life LED’s, eliminating halogen’s need for frequent bulb replacement     [*] Highly configurable, allowing you to build the light sets around your OR     [*] Future-ready universal suspension with the strength and capacity for quick and easy adaptation to future technologiesDATA    [/list]
Bulb Life25000 hr
Depth of Field33 in
Color Temperature4500 K
Lighthead Diameter23 in
Field Diameter5.9 in -11.4"
Intensity: 60,000 – 120,000 lux     Color rendering index: 94     Bulb type: 72 x 1W LED     Electrical: 100/120/127v AC, 240VA
