Four Rivers - TMS OnSite
by Four Rivers
This application allows technicians to track asset data to pro-actively manage your organization's vital information. Our solution of automation tools constantly monitor your departmental activities and pre-defined metrics to maximize your data and your productivity. Using the TMS OnSite application, your organization can improve your regulatory compliance with our reporting module while analyzing the biomed and facility management activities. Your Maintenance and BioMed Technician productivity will increase with the ability to plan, estimate, and schedule. With accurate data, technicians now have the ability to react more quickly improving your customer satisfaction. No healthcare organization has the same needs. With TMS OnSite, you select only the modules you need based on your business requirements.
[list] [*] Access Anywhere: Allow all users the ability to view certain asset data, history, and scheduling information from anywhere. Since TMS OnLine is accessed through the Internet, you can connect to your database from any PC with Internet access. [*] Reduce Equipment Downtime:Proactively managing your PMs means less downtime for your critical assets. Keep equipment downtime to a minimum and eliminate the need for last minute equipment rentals. [*] Accurate Data for Decision Making: Easily track, store, and report on data such as asset information and resource availability based on location or skill. With data such as this easily at your fingertips, your administrators and management can make critical questions more quickly and effectively. [*] Report on Regulatory Compliance Meet reporting requirements set by key regulatory agencies. Track and quickly access the right information when you need it. With over 250 standard reports, it's easy to transform your data into valuable required information. [*] Centralize Multiple Organizations: TMS OnSite has the power to efficiently support just a few up to hundreds of users. Eliminate data synchronization obstacles, centralize data, and improve communication. With one database, you will never have to manually combine data again. [/list]
