Berchtold - Chromophare E 655
by Berchtold
BERCHTOLD’s CHROMOPHARE E 655 uses an efficient 70W HID light source to create an amazing 160,000 lux of max intensity and light field consistency. Its one-piece polygon reflector produces both effective shadow control & deep cavity penetration, and gives the surgeon a uniquely uniform spot, for constant edge to edge viewing within the surgical site. High maneuverability, easy operation, freedom from bulb changes, a multitude of options, and the ability to combine with other lights, flat panels, and equipment booms create a product that is optimized for the entire surgical team.
4Replies8 years ago | Light stuck in sleep mode How do I get it out of sleep modeReply |
8Replies8 years ago | wiring diagram college acquired this surgical light (Chromophare E655) from another campus which didn't have the wiring or installation instructions. Berchtold will not help. Reply |
3Replies9 years ago | Operating Room Light Bulbs I am looking for the replacement bulbs for the Chromophare E 655 Bulbs Can you help me with this? Reply |
[list] [*] 70 watt light source for incredibly efficient operation [*] Maximum intensity allowed by IEC standard for surgical lights [*] Intensity-smoothing polygon optics, for consistent illumination across the field [*] Optics produce both deep penetration and superior shadow control, for use in a wide range of cases [*] Sleep mode, for near instant on/off operation [*] Highly configurable, allowing you to build the light sets around your OR [*] Future-ready universal suspension with the strength and capacity for quick and easy adaptation to future technologies [/list]
Bulb Life | 5000 hr |
Depth of Field | 50 in |
Color Temperature | 4500 K |
Lighthead Diameter | 26 in |
Field Diameter | 6.7 in -11 |
Intensity: 80,000 – 160,000 lux Color rendering index: 96 Bulb type: 70W HID Electrical: 100/120/127v AC, 240VA UL listed
