Berchtold - Chromophare E 805
by Berchtold
The ultimate open-case light. BERCHTOLD’s new CHROMOPHARE® E 805 uses HID technology to create an enormous 13" spot, provide maximum brightness
The ultimate open-case light. BERCHTOLD’s new CHROMOPHARE® E 805 uses HID technology to     create an enormous 13" spot, provide maximum brightness, & consistency. Its one-piece polygon reflector produces both unparalleled shadow control & cavity penetration, and gives the surgeon a uniquely uniform spot, for constant edge to edge viewing within the surgical site. AutoLux™ technology amplifies this effect, keeping light intensity constant regardless of spot size. High maneuverability, easy operation, freedom from bulb changes, a multitude of options, and the ability to combine with other lights, flat panels, and equipment booms create a product that is optimized for the entire surgical team.
[list]    [*] Enormous bright, color-correct spots up to 13" in diameter     [*] Maximum intensity allowed by IEC standard for surgical lights     [*] Intensity-leveling AutoLux technology, so light stays the same even as the spot size is adjusted     [*] Power reserve, adding light to the big spot when you need it most     [*] Deep, consistent light field, even when raising or lowering the patient     [*] Sleep mode, for near instant on/off operation     [*] Highly configurable, allowing you to build the light sets around your OR     [*] Future-ready universal suspension with the strength and capacity for quick and easy adaptation to future technologies    [/list]
Bulb Life5000 hr
Depth of Field55 in
Color Temperature4500 K
Lighthead Diameter31 in
Field Diameter7.8 in -13"
Intensity: 80,000 – 160,000 lux     Color rendering index: 96     Bulb type: 150W HID     Electrical: 100/120/127v AC, 240VA
