Embla - SD32+™
by Embla
Sleep Diagnostic Amplifier
Powerful, easy to use and simple to calibrate, the SD32+™ amplifier offers sleep labs all the functionality of an advanced 32-channel digital sleep diagnostic amplifier, plus the option for 8 additional DC channels.
-efreeman
Wed Jun 25 2014
Sandman didgital 32 amp
Have two unit that will not stay connected to computer for sleep study. Have ruled out all cables, problem in amplifier itself. Does anyone know of anyone that works on these except EMBLA?
SERVICE COMPANIESView All Electroencephalograph (EEG) Companies
[list]      [*] Featuring built-in Nellcor oximetry for simplified calibration and tracking of true SpO2 and pulse rate values      [*] Convenient LCD screen to display the impedance check, signal quality check, numeric digital values or montage setup at the patient’s bedside      [*] Plug-and-play interface with GoodKnight™ 425ST Bi-Level™ device via Sandman elink™ adapter      [*] Slim, lightweight headbox with quick disconnect for easy patient mobility      [*] Fully programmable references, filters, gains and sampling rates from within Sandman Elite software      [*] Multireferencing and re-referencing of any channel during collection from within Sandman Elite software      [*] Flexibility for your entire sleep or neurodiagnostic recording needs      [/list]
Physical Characteristics             Amplifier      [*] Size (L x W x H):       0.2"x 6.8" x 2.2"       250 x 170 x 65 mm      [*] Weight:      3.0 lb      1.36 kg      Physical Characteristics :      Head box      [*] Size (L x W x H):      5.2" x 3.8" x 2.5"       126 x 96 x 25 mm      [*] Weight:      < 0.5 lb      0.2 kg      Physical Characteristics :      DC Expansion Box      [*] Size (L x W x H):      4.8" x 2.8" x 2.2"      120 x 70 x 55 mm      [*] Weight:      0.5 lb      0.2 kg
