Smiths Medical - BCI 3303
by Smiths Medical
Hand-Held Pulse Oximeter facilitates spot checking and continuous SpO2 and pulse rate monitoring for home-care use.
Hand-Held Pulse Oximeter facilitates spot checking and continuous SpO2 and pulse rate monitoring for home-care use, as well as at the hospital bedside or for land or air transport situations. Stores data for later sleep screening analysis via a PC or commercially available printer. It’s precisely the kind of reliable performing device you’d expect from the global leader in hand-held pulse oximetry technology.
-arfajmedical
10 years ago
Urgent Request For Quotation.
we are Distributor of medical Products in Saudi Arabia, and recently has a request to quote for " BCI 3303 Hand held Pulse Oximeter".. Qty: 5/ea..
so please send us your best offer to us as Distributor..
SERVICE COMPANIESView All Pulse Oximeter Companies
• 3 operating modes enhance user convenience. (Clinic, home and sleep) • Allows menu-free operation via one touch, direct-function keys. • Easily adjust LED display brightness to optimize viewing. • Pulse strength bar on screen. • Adjustable alarm limits for SpO2 and pulse rate. • Instantly distinguish between audible patient alarms and system alerts. • View patient history on-screen; recall up to 99 patient SpO2 and pulse rate readings with 24 hour memory. • Protective rubber boot included. • Pole mount available. • Internal rechargeable NiMH battery. • Genuine BCI® reusable and disposable sensors available.
• SpO2 LED numeric display 0.43 inches (11 mm) high • Pulse Rate LED numeric display 0.375 inches (9.5 mm) high • Pulse Strength Logarithmically scaled 8-segment LED bar graph • Low Battery LED flashes when approximately 30 minutes of battery life remains • Alarm Silence LED flashes or lights to remind the user that audio alarms are disabled • Sensor LED flashes to alert the operator to check the SpO2 sensor placement SpO2 • Range 0 to 100% • Accuracy ±2% at 70-100%; ±3% at 50-69% • Averaging 4, 8, or 16 pulse beat average • Alarm Range High: 50%-100% and OFF (1% steps) Low: 50%-99% and OFF (1% steps) PULSE RATE • Range 30-254 bpm • Accuracy ±2% at 30-254 bpm • Resolution 1 bpm • Averaging 8 or 16 seconds • Alarm Range High: 5-250 bpm and OFF (5 bpm steps) Low: 5-250 bpm and OFF (5 bpm steps) MEMORY Spot checks and trends can be stored for up to 99 patients and 24 hours of run time (12 hours in sleep mode) Auxiliary Serial Printer/ Computer Output Data saved every thirty seconds can be printed or downloaded to a PC (trend) Data saved every four seconds in sleep mode can be output and processed by commercially available sleep study software Dimensions 7.25" H x 3.3" W x 1.85" D (18.4 cm H x 8.4 cm W x 4.7 cm D) WEIGHT 19 oz. (539 grams) Powerower Requirements • AC Power 105-125 VAC, 60 Hz 208-252 VAC, 50 Hz (optional) 90-110 VAC, 50/60 Hz (optional) • Battery Standard NiMH (Nickel Metal Hydride) Batterattery Life Internal rechargeable, not user replaceable. Fully charges in about 6 hours. Approximately 24 hours of continuous use. Environmentaironmental • Operating Temperature -4°F to 131°F (-20°C to 55°C) • Storage Temperature -40°F to 167°F (-40°C to 75°C) • Relative Humidity (non-condensing) 10-95% (storage) 15-95% (operating) Mechanicaechanicaechanicaechanicaechanicaechanicaechanicaechanical Durabiurabiurabiurabiurabilitity Test Results • Vibration Testing In compliance with IEC 68-2-6, IEC 68-2-34 • Shock Testing In compliance with IEC 68-2-27 • Drop Testing Exceeded UL 544 testing recommendations Standardstandardstandards EN60601-1, EN60601-1-2, UL 544 Regulatoratoratory Compliance ISO 9001/ISO 13485 Cataataatalog Number • 3303 Hand-Held Pulse Oximeter
