Lighthouse Imaging - EndoLume
Endoscopic System Light MeterEndoLume is a portable handheld instrument, that consists of a custom-designed integrating sphere and light detector, precision light meter with digital display and adapters to connect with all endoscopic equipment common in medical institutions. Light values are displayed in lumens, the unit measure of luminous flux or the total amount of visible light.
[list] [*] Calibrated to NIST traceable standards [*] Rugged and compact design with [*] 9V battery-powered with low 5 digit display battery indicator [*] Five foot cable to reach all areas [*] Auto off after four minutes of endoscopy rack [*] Adapters for all standard [*] Patented Optical Bridge light-sources, light cables and technology provides accurate endoscopes included endoscopic light-source measurements [*] New ergonomic locking mechanism for adapters [*] One button operation for ease of use [*] Measures light output of both [*] Built-in color correction filter rigid and flexible endoscopes simulates the spectral response of the human eye [/list]
Height | 32 mm |
Length | 150 mm |
Weight | 13 oz |
Width | 83 mm |
Accuracy: +/- 5% Range: 0-5,000 lumens Endoscope Diameter Range: 2-15mm with included clamping collar; 15-16mm direct connection
