BioTek - ELx800
Microplate Reader
The ELx800™ is designed for applications within the clinical, biotechnology research and pharmaceutical laboratory. Its compact footprint and proven robust design makes it an ideal solution for many microplate based biological assays. The ELx800 can be controlled by Gen5 software, expanding the readers capabilities to include kinetics and well area scanning measurements. Gen5 offers unsurpassed data reduction capability as well as customizable data output options. When standalone use is preferred, the ELx800 on-board software is extensive for a variety of qualitative and quantitative applications.
FORUMSView All (4)
1Reply3 years ago | ERRO 0302 Hi , My microplate reader Elx800 give error 0302 and i cannot find it in the manual. how to fix itReply |
2Replies4 years ago | KC4 SOFTWARE Can anyone help with KC4 software and installation for Elx800 thanksReply |
0Replies8 years ago | software Hello I need the software of ELX 800 or ELX 808Reply |
- Multiple Plate Formats
- Superior Hardware Design
- On-Board Diagnostic Testing
- Compact Footprint
- Gen5 Data Analysis Software (optional)
Weight | 18.5 lbs |
- Read method: End point, kinetic and well area scanning via computer control
- Microplate types: 6-, 12-, 24-, 48-, 96-well microplates 384- and 60/72/96-well Terasaki plates (NB option)'
- Software: Gen5 Reader Control Included
- Onboard Software: 55 user-programmable protocols
- Light source: Tungsten Halogen
- Wavelength selection: Filters
- Wavelength range: 400 to 750 nm 340 to 750 nm (UV option)
- Bandpass: 10 nm
- Dynamic range: 0 to 3.0 OD
- Resolution: 0.001 OD
- Filter wheel capacity: 5 positions
- Filters supplied: 4 filters (5 with UV option)
- OD accuracy: <1% at 2.0 OD typical
- OD linearity: <1% at 2.0 OD typical <3% at 3.0 OD typical
- OD repeatability<0.5% at 2.0 OD typical
- Reading speed: 96 wells: 30 seconds
- Power: 100-240 VAC 50/60 Hz
- Dimensions: 16.5"D x 15"W x 7"H (41.9 x 38.1 x 17.8 cm)
- Weight18.5 lbs (8 kg)
- Regulatory: For In Vitro Diagnostic use. CE and TUV marked.
