Medstone - TM5
by Medstone
The “Elite”series of imaging tables are designed for high patient throughput utilizing the highest quality components and designed for ease-of-use by the medical staff with patient comfort in mind. The tabletop has been designed to give maximum unobstructed imaging allowing 360º rotation radiation-free coverage around the longitudinal axis of the carbon fiber tabletop which makes it ideal for 3D imaging studies. The tabletop pad is also designed to give the patient maximum comfort being manufactured utilizing our patient form-fitting Visco/Memory “Sofcare” High Density foam.
[list] [*] Longitudinal Travel [*] Trendelenburg / Reverse Trendelenburg [*] Lateral Travel [*] Lateral Tilt [*] Elevation [*] 500 lbs Patient Weight Capacity [*] 58″ Of Unencumbered Rotational Imaging Area [/list]
| Tredelenburg | 15 degrees |
| Lateral Tilt | 15 degrees |
| Patient Weight Capacity | 500 lbs |
