C-Arm Imaging Table
The Oakworks CFPM401 C-Arm Imaging Table is a new, cost-effective table designed to accommodate mobile and ceiling suspended C-Arm systems. The CFPM401 is a 4-movement table that has all of the features required for successful pain management, image-guided procedures. Its dynamic height range of 26” to 44” (66cm to 112cm) accommodates low height patient wheelchair transfers to maximum height C-Arm mobility requirements for full lateral imaging.
-Data Entry Coordinator
10 years ago
CFPM401 Video
VIDEOS
CFPM401 Video
[list]      [*] The table is mounted on a new low profile base and can be moved easily from room to room and secured with 4 locking casters.      [*] This table promotes a 56” (142cm) metal free imaging area for maximum C-Arm efficiency and is controlled by 1 hand control and 1 foot control unit.       [*] The integrated head rest carbon fiber top is capable of a 10” (25cm) manual longitudinal travel, 15° Trendelenburg tilt, 12° reverse Trendelenburg tilt and 4° Lateral travel while at the same time supporting up to 500 lbs (227 kg) of patient weight      [/list]
Weight415 lbs
Table Top Dimensions: 22” (56 cm) x 84” (213 cm) Carbon Fiber with Integrated Head Rest      Metal Free Imaging Area: 56” (142 cm)      Patient Weight Capacity: 500 lbs. (227 kg.)      Frame: Single Tower Steel Base      Electronics: 110VAC lift motor + 2x24VDC tilting motors
