Skytron - 6000
by Skytron
The Skyton 6000 / 6001 line of surgical table is a versatile and dependable operating room table that is c-arm compatible.The Skytron 6000 series of tables overs a verity of options such as sold and split legs, kidney bridges, and a battery for cordless operation.
[list] [*] Control from any point around the table with one-touch pendant control. [*] Positioning is safe and easy using the table’s easy-to-read symbols. [*] Provides adequate toe space and mayo stand clearance with its narrow base design. [*] Features a radiolucent top that provides clear, sharp patient imaging capability. [*] Easily clean the durable, stainless steel base and column. Also easily clean between cases using swivel casters, which provide side movement. [*] Fully mechanical manual brake release utilizes no battery power for emergency use. [*] Provides C-arm access to nearly all of a patient’s anatomy. [*] Features a reversible head section you can adjust to accommodate tall patients. You can also use it as a foot extension during patient transfer. [/list]
Length | 70 in |
Tredelenburg | 30 degrees |
Lateral Tilt | 30 degrees |
Patient Weight Capacity | 400 lbs |
Width | 20 in |
