Medical Illumination - MEDI-LITE REFLECTOR LIGHT
by Medical Illumination
Reflector light.
FORUMSView All (19)
-Celeste
Wed Sep 04 2019
Medi Lite handle replacement
Looking for a replacement handle for the Medi Lite Model #011314. Medical Illumination does not make the part anymore.Reply
-RichD12
Sun Jul 07 2019
Replacement bulb casts shadow
The unit has a label to use 0001727 replacement bulb. Ordered 150T10/HAL-SHORT from Interlight.biz and verified from them that this is the correct replacement. However, this bulb casts a dark shadow in the center of the beam. Had to put the old bulb back in. Any suggestions on a replacement that will not cause the shadow issue? ThanksReply
3
-Emerson Scott
Mon Jun 03 2019
Heat absorbing color correcting cylinder
Broke the green cylinder so need to see if anyone has one for sale Reply
[list]    [*] 3,500 ft candles (37,700lux) at 36" (914mm) distance     [*] 3,700º Kelvin color temperature     [*] Quartz/halogen bulb for long life     [*] 13" (330mm) diameter reflector for great shadow reduction     [*] Heat-absorbing, color-correcting glass cylinder     [*] 42" ( 107cm) arm extension to center - a full diameter of 84" (214cm) coverage     [*] Removable, sterilizable handle     [*] Available as wall, portable floor, single or dual ceiling mounts, combination ceiling mounts w/ Medi-Spot or E-Z Glide ceiling track mount    [/list]
Bulb Life2000 hr
Color Temperature3700 K
Lighthead Diameter13 in
Field Diameter36 in
Light Intensity at 36" 3500 foot candles     Light Source 150 W Tungsten Halogen Bulb     Rated Bulb Life 2000 hours     Field Size at 36" 6" Dia.     Reflector13" Dia. Alzak     Filter Type I/R Filter Glass     Input Voltage Range 110-125 Vac 50/60 Hz     220-240 Vac 50/60 Hz     Lamp Head Rotation 350 Deg.     Light Head Dimensions 13.62" Dia. X 12.00" High     Articulating Arm Length 29"     Extension Arm Length 16"     Weights:     Wall Model 10.5 pounds     Portable Floor Model 32.3 pounds     Single Ceiling Mount 26 pounds     Dual Ceiling Mount 35 pounds
