Tuttnauer - Elara 11D
by Tuttnauer
The Elara 11D tabletop autoclave
The Elara 11D tabletop autoclave is a reliable and robust Class B Autoclave designed for the needs of modern clinics where autoclaves are expected to meet sophisticated international standards and operate non-stop every day. Elara Autoclaves are designed for the sterilization processing needs of Medical Clinics, Dental Clinics and Veterinary Clinics.
-Chris-CBET
a year ago
temperature calibration - elara 11D
What is the disc in the rear of the chamber(inside) and how am i supposed to get the temp probe form teh cal kit passed it?
-Alexandria
8 years ago
Elara - Tuttnauer
Elara tabletop autoclave sterilizers (19 to 28.5 liter chamber) with built-in steam generator are designed for the sterilization applicatons in Medical Clinics, Dental Clinics and Veterinary Clinics.
Elara autoclave is a reliable pre & post vacuum (Class B) sterilizer that complies with strict international standards for destroying harmful micro-organisms and spores.
30% EXTRA TRAY CAPACITY
• You get longer trays providing 30% extra tray space compared to other autoclaves that offer 17 to 20 liter chambers.
• Extra capacity per cycle requires less cycles per day, saving you energy costs and water.
LONG LASTING AUTOCLAVE
Top Quality Stainless Steel
• Durable 316L stainless steel electro-polished chamber lasts longer than competing 304 stainless steel chambers
• Stainless steel door with mirror polish surface is highly resistant to corrosion
Built-in system for checking water quality
• Automatic water quality checking will alert the user of poor water quality. Protect the autoclave chamber from corrosive minerals in poor water.
CONVENIENT
Water Filling
• Front water filling allows you to use the space above the autoclave
• Top water filling is also available
• Automatic feed water (optional) will automatically fill the autoclave reservoir with water
Door
• Self-locking door designed to easily close/open door with one hand
SAFETY
• Two different locking mechanisms prevent the door from opening while the chamber is pressurized
• Cycle will not start if the door is not locked
• Door will not open at end of cycle until chamber pressure equalizes to room pressure
ENERGY SAVER
• Sleep Mode - allows user to set time to switch sterilizer to minimum energy consumption
• Low Rate Cycle - you can run your sterilizer when electrical power costs are low, like after work hours, by setting a delayed start time.
DISPLAY & DATA MANAGEMENT
• Advanced control system with multi-color display & multi-lingual (26 languages)
• Download data for 200 cycles to your USB memory device
Class B performance is achieved with a built-in vacuum pump used for prevacuum air removal eliminating air pockets from all load types and maximizing efficient steam penetration throughout the entire load. After the sterilization stage the vacuum pump is used for post-vacuum to assist drying.
VIDEOS
Elara - Tuttnauer
[list]            [*] High speed Class B performance with powerful built-in steam generator            [*] Advanced control system with multi-color display            [*] Download cycle data your USB memory device            [*] Built-in water quality checking feature            [*] Self-locking door with double safety locking mechanism            [*] Top Quality Stainless Steel            [*] You can run your sterilizer when electrical power costs are low, like after work hours, by setting a delayed start time            [/list]
Chamber Volume28.5 L
Height430 mm
Chamber Height280 mm
Length 592 mm
Weight184 lbs
Chamber Depth430 mm
Width530 mm
Tray Capacity:Pouch Capacity: 24
