LW Scientific - C3
Select CentrifugeThe C3 spins 3ml-15ml test tubes up to 3000 rpm. It has tighter straight-line gel separations in order to reduce re-spins and re-mixes and allows for veterinary fecals to spin with coverslips on the tube. Horizontal separation offers many advantages over traditional fixed-angle separations, including tighter straight-line gel separations to reduce re-spins and re-mixes. Additionally, spun fecal floatations in the veterinary markets produce much higher ova recovery results when spun with coverslips on top of the test tube. The C3 Select spins 3ml-15ml test tubes, up to 17mm x 128mm, at speeds up to 3,000 rpm. Select either blood, urine, or fecals on the speed control, set the 30-minute timer, and the C3 Select will spin at the correct speed. The all-metal rotor is built for strength and durability, and the wide-mouth metal bowl allows for easy cleanup. The whisper-quiet, brushless, heavy-duty motor can handle high volume use and high-speed full loads for years to come.
1Reply10 years ago | LW Scientific C3-Select centrifuge keeps turning off When the timer is turned to start the centrifuge, it clicks on and begins to spin. Audible click & spin. After 1-2 seconds, it clicks off. Audible click off and you can also hear the spinning slowing. I can open the lid and see it spinning but it eventually slows to a stop. The timer continues to run and eventually goes off. I can start it again, clicks on...1-2 secs...clicks off. Any ideas? Thanks! EDIT: Sorry! This should be posted in the Centrifuge sub-forum. Reply |
[list] [*] Straight-line separation for accurate processing [*] Pre-calibrated blood, urine, and fecal speeds [*] Reduces high potassium results in blood [*] Tighter gel line reduces re-mixing [*] Veterinary fecals spin with coverslips on the tube [*] Much higher ova recovery than standing fecal tests [/list]
Height | 12 in |
Length | 18 in |
Weight | 33 lbs |
Maximum Speed | 3000 rpm |
Width | 14.5 in |
Maximum tube size: 17.5mm x 133mm
