Medical Illumination - CENTURA FULL VARIABLE SPOTLIGH
by Medical Illumination
This full-featured spotlight gives exceptional performance and versatility in a truly unique design. Used independently or in combination
This full-featured spotlight gives exceptional performance and versatility in a truly unique design. Used independently or in combination with other lights such as the Centurion, the clean, streamlined Centura creates a tightly focused, high intensity light pattern. The Centura also features the 21st Century Series' exclusive Centra arm delivery system and an optional built-in fiber optic lightsource for connection of fiber optic headlamps or instruments.
[list]  [*] Continuously adjustable spot from 3" (76mm) to 16" ( 406mm) diameter , providing homogenous light with 2,000 ft candles (21,500lux) at 36" (914mm) distance    [*] Color temperature of 3,500º Kelvin    [*] Easily replaceable 20 volt 150 watt halogen bulb with integral dichroic reflector    [*] IR absorbing, color-correcting glass filter    [*] Mechanical iris dimmer provides constant purity of light without affecting color temperature    [*] 28" (711mm) articulating arm with integral compression spring    [*] 23" Extension Arm    [*] Arm rotates 40º up and down from horizontal plan    [*] Lamphead and arm both rotate 540º    [*] Standard sterilizable handle    [*] Available with optional built-in fiber optic lightsource    [*] Available in portable floor, wall, single or dual ceiling mounts, combination ceiling mounts with Centurion and ChuttleTrak ceiling track mounts.    [/list]
Bulb Life500 hr
Color Temperature3500 K
Light Intensity at 36" 2000 foot candles    Field Size at 36" 3" - 16" Dia. Adjustable    Reflector 2" Dia. Dichroic glass    Filter Type Hot Mirror/ I/R Filter Glass
