Kendall - AVI 6060
Sequential Compression DeviceThe Kendall 6060 uses a foot sleeve with a rigid base which fills with air and then deflates in a programmed cycle, similar to the stimulation from walking. This device has push button control and an LCD display, which displays the pressure status in mmHg. Uses the same air hose on each side, and the same left and right Impads for inflation as the earlier 5000 model.
FORUMSView All (5)
2Replies2 years ago | Back blue hose holder Looking for the part number of the back blue piece that holds the tubing and lists the fault codes. I have one that is cracked and needs replacement Reply |
1Reply4 years ago | Servicing is there a compressor servicing kit for this unit ?Reply |
1Reply8 years ago | Service Looking to place these units on an AEM program. Looking for Maintenance requirements from the Manual but can't find our manual. Reply |
- 0.4 second rapid inflation simulates the weight bearing process.
- An anatomically shaped IMPAD inflation bladder insures the plantar plexus is completely covered during impulsing.
- The rigid sole incorporated in the foot cover option contains and directs the impulse.
Height | 6.4 in |
Weight | 7.5 lbs |
Width | 9.2 in |
Power: 120V, 0.6A, 60Hz
Output Impulse Pressure: 60-200 mmHg
Impulse Duration: 1 or 3 seconds
Cycle Timec: Impulse delivered every 20 seconds
