Datex Ohmeda - Aespire 7900
Combining the proven ergonomic excellence of the Datex-Ohmeda Aespire family with the world class ventilator.
The 7900 Smartvent provides advanced features in a contemporary stylish design. Optional modes like PSV and Simv optimize your ventilation choices while features such as dual flow tubes, decelerating pressure control, low maintenance breathing circuit are standard. When performance is paramount, Aespire 7900 delivers.
FORUMSView All (3)
2Replies22 days ago | AGSS / active & passive scavenging systems I am trying to obtain tech info including installation, adjustment & testing of active & passive scavenging systems for the Aespire 7900 anaesthesia machine. Thank you in advance for your assistance. Equipment: Datex Ohmeda - Aespire 7900 Anaesthesia Reply |
4Replies5 years ago | PEEP problem Good day colleagues, i have a GE Aespire that holds some extra 10cmmH2O at the end of exhalation, PEEP is off and some time turn on the back pressure alarm. Do you have any experience with this problem? Thanks.Reply |
3Replies8 years ago | maintenance what is the procedure for cycling the MOPV,unable to find the Aestiva 7900 SmartVent TRM. Reply |
- Unparalleled ventilation
- Advanced ventilation modes include PSVPro
- System is lightweight and compact for easy maneuverability
- Large work surface offers more room for supplies and chart
- LED light strip provides bi-level work surface illumination
- Bellows provide quick visual confirmation of the integrity of breathing system
- High-quality pneumatic flow mixing
- Auxiliary common gas outlet facilitates low-pressure leak test
PSV Pro
- Assists in overcoming the resistance within the breathing circuit and patient circuit, helping decrease the patient's work of breathing
- Helps counter the reduction in the patient’s functional residual capacity (FRC) and the decrease in muscle contraction due to the anesthetics
- May be used with LMAs due to its lower airway pressures
- With automatic apnea backup mode, uses an SIMV-PC + PSV mode to maintain a minimum minute ventilation in the event the patient stops spontaneously breathing.
- With adjustable inspiration termination, allows fine-tuning to the patient’s breathing pattern.
- Supports virtually all spontaneous breaths
- Uses a decelerating flow pattern (optimizes inspiratory flow)
- Sustains or enhances the patient’s tidal volume and etCO2 maintenance
