Defibrillator
Zoll's AED Plus features Real CPR Help, a tool that is able to actually see what you are doing and provide feedback to help you do it well. Audio and visual prompts help you rescue with confidence and clarity, unmatched by any other automated external defibrillator (AED). The Zoll AED Plus will tell you when to push harder or say "Good compressions." A metronome will lead you to the right rate and it will even show you the depth of each compression in real time. The AED Plus will tell you again to get started. In addition, the Zoll AED boasts support for the complete Chain of Survival, help to all victims of SCA, even those for which no shock is advised, a one-piece pad for fast and accurate placement, consumer lithium camera batteries commonly available from retail stores, intelligent pediatric capability, Zolls Rectilinear Biphasic Waveform, total AED Program Management with En-Pro, and Guidelines 2005 Ready.
- Heart defibrillator has a built in Text Display with Voice Prompts
- FSA Eligible
- Analyzes heart rhythm and informs the rescuer if the rhythm is shockable or non-shockable.
- Delivers defibrillation treatment to victims of cardiac arrest who exhibit shockable ECG rhythms.
- Sequenced LED array gives fast communication of specific rescuer actions needed at the correct time.
- Voice prompts and graphics guide the rescuer regarding what to do and when to do it during a cardiac emergency - such as calling for help or giving CPR to the patient.
- Monitors the depth and rate of chest compressions during CPR and provides voice prompts
- Notifies user of good compressions that are at least 2 inches deep and at a rate of 100 per minute
- Notifies users if compressions are inadequate and when to push harder and/or faster
- Meets the FDA's guidelines for requiring that chest compressions be at least 2 inches deep
- Audible beeps encourage rescuers to provide CPR compressions at 100 CPM (requires Zoll CPR-D Padz)
- Performs periodic self test to ensure its continual readiness
- Unit cover functions as a Passive Airway Support System (PASS).
- Resists dust and water
Weight | 6.7 lbs |
Defibrillator Type | External, Automated (AED) |
