Olympus - CLV-180 Xenon
by Olympus
EVIS Exera II high intensity 300W xenon light source for Olympus color CCD videoscope system
EVIS Exera II high intensity 300W xenon light source for Olympus color CCD videoscope system with specially coated filters for Narrow Band Imaging (only for GI) and emergency 100W Halogen lamp
FORUMSView All (3)
-fbell
Fri Jul 15 2016
reset lamp hours
clv 190 reset needed
-Biomed George
Wed Sep 16 2015
hours reset procedure
need help on resetting the light meter for the exera II clv-180 light source
-Doug McIntire
Mon Aug 11 2014
reset lamp life
[list]        [*] Water Feeding        [*] Automatic Brightness Control        [*] Air Feeding        [*] Setting Memory        [*] Illumination        [*] Indicators on Front Panel        [*] Equipped with speciality coated filters for MBI (Narrow Band Imaging). (only for GI)     [*] Lamp can be turned on/off without turning off the equipment.     [*] Automatically adjusts light intensity to achieve ideal illumination for observation of the gastrointestinal tract.     [*] Powerful 300-watt xenon lamp.     [*] Backlit front panel and controls improve operability.    [/list]
Height162 mm
Weight15.4 kg
Width381 mm
Voltage: 100-200 V, 220-240 V AC          Voltage fluctuation: Within + 10%          Frequency: 50/60 Hz          Frequency fluctuation: Within + 1Hz          Consumption electric power: 500VA          Fuse rating: 8A, 250V          Fuse size: Ø5mm x 20mm
