GE HealthCare - LOGIQ S7
by GE HealthCare
With the growing use of ultrasound, healthcare providers are challenged to image patients of various ages and sizes, and encompass a wide range of clinical areas. It takes a special ultrasound system to help meet those demands and the new LOGIQ S7 system is equipped for the challenge.
1ReplyWed Feb 04 2026 | Logiq s7 system error On completing boot message system error appears Clicking OK button it disappears, boot is complete but without ultrasound image, scanning is disabled. Running self test Many fails apper, the first fail is Callisto memory test Noise floor test BF Analog RX gain HV MUX test Presence test Version test And few others I did the following but no success: - reseat all pcb - detach battery - reload base software and application - clean trancducer contacts - use another known good transducer - checked all bios settings to match the list in service manual What else could I do? |
2RepliesThu Jun 02 2022 | Cant Load SW Trying to load SW. Unable to set SATA 0 in boot device priority. Only gives SATA 1 and Disable as options. Any suggestions?Reply |
3RepliesMon Dec 09 2019 | SERVICE MANUAL SERVICE MANUALReply |
| Clinical Applications | Radiology |
