GE HealthCare - Vivid S6
The Vivid S6 is uses automated tissue characterization optimization to help the operator quickly optimize image quality.The ergonomic design and easy-to-use features of GEs Vivid S6 allows users to take workflow and productivity to the next level. Excellent performance through a wide range of applications coupled with a broad selection of transducers, exceptional image quality, innovative miniaturization, comprehensive connectivity options, and a range of advanced, automated tools make this an exceptional cardiovascular and shared-service solution to help meet the daily demands of any practice.
FORUMSView All (7)
1Reply3 months ago | Probes are "freeze" Hello! Vivid S6, aged since 2011, but still a necessary device. Everything works, everything turns on, all buttons are pressed and active. It detects both sensors, allows you to select them and select a scanning program! The problem is that the picture of the image seems to be in a constant “freeze”. Does not react at all to the surface of the probes! Both probes are the same! A full diagnostic test did not reveal any errors - everything is "PASS"! Can someone tell me where to go and who to fight, and whether to fight? Thank you in advance! Equipment: GE HealthCare - Vivid S6 Reply |
1Replya year ago | Software can not reload SW on a new IDE hard drive Equipment: GE Healthcare - Vivid S6 Reply |
2Replies2 years ago | Vivid S6 is not turned ON. On/Off Button is not lit Hi there, i have run into a problem on Vivid S6. Suddenly it shut down and was not turned any more. On/Off Button is not lit (not amber, not green). The display is dark. Keyboard is not lit. I consider a power supply. The bottom AC box (itself) is functioning (provides 20v and 5V, 12V when control signal is provided from the outer power source). Without the outer signal, the AC box gives 20V only and Vivid doesn't start. I changed the DCDC supply. Useless. I hear weak noise coming from it. I checked the BEP (computer) and replaced the battery on it. Useless. How can I check the computer (BEP) in this case? What else to try? Did anybody meet this? Reply |
VIDEOS
- Ultra definition algorithms for speckle reduction.
- Clarity and Adaptive Reject to help optimize image quality.
- Ultra-high frame rates.
- Smart Depth automatically adapts imaging parameters.
- Productivity. Automated options allow for easy acquisition and enhanced image quality through a wide range of applications.
- Image Quality Optimization. One touch, optimized image quality for challenging patients. Helps preserve efficient workflow with obese patient populations.
- Quantitative. Automated speckle-tracking strain (healthymagination certified AFI)
- Auto-EF tools helping to improve productivity and reach a confident diagnosis.
- Convenience. Access. Patients and staff benefit as the Vivid S6 delivers imaging and analysis in a broad range of applications (cardiac, vascular, abdominal, pediatric/fetal, OB and OR).
- Mobility. An ergonomic design helps reduce fatigue and discomfort.
- Compatibility. A wide range of advanced connectivity options help users streamline their workflow.
Clinical Applications | Cardiology |
