Pentax - ES-3870K
by Pentax
Video Sigmoidoscope
The ES-3870K is ideal for examination or treatment of the rectum and sigmoid, where many pathological changes in the colon occur. The 700 mm long insertion tube is easy to handle. Instruments are easy to insert even at maximum tip deflection and suction is possible with instruments inserted. The scope is equipped with PENTAX's unique forward water jet function.
[list]    [*] Full screen display size give superior image quality    [*] Compatible with EPK-I, EPK-1000 & EPK-700    [/list]
Length 70 cm
Diameter: 12.8mm    Working Length: 70cm    Instrument Channel: 4.2 mm    Field of View: 140 degrees    Angulation Range: Up: 180, Down: 180, Right: 160, Left 160
