Philips - Intera 1.5T
by Philips
MRI System
The Philips Intera 1.5T MRI machine is a high field scanner that affords users levels of customizability to perform exams any way users want. The Philips Intera 1.5T MRI features a revolutionary ultra-compact magnet, excellent image quality and a wide, open, patient-friendly design.
FORUMSView All (3)
-Majid Yousefi
Mon Oct 19 2020
tunning and matching phase
What are the causes and solutions for this error?Reply
2
-Jason Price
Fri Oct 02 2015
Correct Cryo Levels
Our Imaging contractor is claiming that a safe cryo levels for our machine is 40%, and that the machine is perfectly safe down toe 30%; another contractor recommended never allowing the machine to drop below 55%. What is the recommended cryo range for this machine?
-J. Vergara
Wed Feb 20 2013
Body Coil Wanted
I am looking for the part# 452213219858 for the Body MRI coil.
Any information about where could I purchase one will be highly appreciated.
  • Ultra compact and friendly design
  • Lightweight
  • Wide patient opening
  • Table speeds of 20mm/s to 180mm/s
  • Soft mattress with head rest
  • Patient comfort zone
Magnet TypeSuperconducting
Weight6400 lbs
Clinical UseWhole Body
Gantry (Max. Clearance) 60 cm flaring out to 120 cm
Magnetic Field Strength1.5 T
Patient Weight Capacity550 lbs
  • Minimum room size (length x width x height) : 3.6m x 5.4m x 3.0m
