STERIS - Surgimax
by STERIS
An electro-hydraulic general surgical table specifically configured for the clinical and economic requirements of ambulatory surgery care. Comprised of a full posturing six section interlocking tabletop supported by a column and mobile base assembly. Top includes powered back section, raise/lower, Trendelenburg and lateral tilts. A complete and separate accessory accompaniment is available. Includes: 6 section interlocking tabletop, 1,100 lb (499 kg) weight capacity (patient centered over column); 600 lb (272 kg) all functions, 24” to 35” (600 to 900 mm) height adj., return-to-level functionality, dual perineal cutout, battery power, pendant hand control, integrated auxiliary back-up control system, mobile base with locking casters and self-compensating floor locks.
0RepliesWed Apr 12 2017 | steris 5085 surgical table needing a manualReply |
[list] [*] adapts to handle any procedure (GI, orthopedic, pediatric, bariatric, etc.) [*] offers a low working height for ophthalmology, ENT and minimally invasive surgeries [*] delivers flexible patient positioning and articulation [*] enables ample access for fluoroscopy equipment [*] is easy-to-use (no complicated controls) [*] exceeds the rigorous demands of an operating suite [*] addresses large patient loads safely [*] leverages your existing table accessory inventory [*] Outstanding low position [*]Versatile table articulation [*]Maximum C-arm access [*]Outstanding low position [/list]
| Height | 600 mm to 900 mm |
| Weight | 475 lbs |
| Tredelenburg | 40 degrees |
| Lateral Tilt | 20 degrees |
| Patient Weight Capacity | 1100 lbs |
| Width | 20.5 in |
Back section articulation (up / down): +90° / -90° Leg section articulation(up / down): 80° / -90° Auxiliary override: Yes Perineal cutout: Yes Upper body imaging area: Normal Orientation (35x15") - 525 sq. in. (3387 sq. cm) Reverse Orientation : (38x15") 570 sq. in. (3677 sq. cm) Lower body imaging area: Normal Orientation (27x15") - 405 sq. in. (2613 sq. cm) Reverse Orientation: (24.5x15") - 367 sq. in. (2368 sq. cm)
