Luxtec - MLX 300
by Luxtec
Surgical Light
The Integra Luxtec MLX 300 xenon light source is one of the premiere light sources in the entire surgical industry. Sunlight is the ideal light for humans to work. It gives you the color distinction you need in surgery. The MLX Xenon lightsource gives you true white light, not harsh actinic white light with blue shading. The MLX Xenon Lightsource gives you true white light, not harsh actinic white light with blue shading
FORUMSView All (7)
-Hill452
3 years ago
I need to replace power entry module, does anyone have a part #
I need to replace power entry module, does anyone have a part #Reply
5
-Riz
4 years ago
New Bulb Not Fire
I have a strange issue. I have 2 units . 1 unit has defective lamp, I tried replacing with a new lamp module the lamp does not work., but when i took the lamp module from other unit and install in the first unit it start to work,  So this clearly shows that Power supply if working as well. Please help me in identifying the problem and recitfing itReply
-New Guy
6 years ago
Burning smell
I have MLX that is producing a burning smell. The smell is coming out of the hole the light comes out of. I was told there could be some misalignment going on. If this is true what should I look for. Reply
  • Increased Lamp Warranty - 1000 hours
  • New Floorstand
  • Membrane Touchpad Controls
  • Stand-by Switch: System starts up in Stand-by Mode
  • Allows electronic self-check
  • Starts up at the same light output setting
  • Lower center of gravity
  • LCD Display
  • Precise light attenuation in 5% increments
  • Lamp Age meter
  • System Age meter
  • System Fault display
Height5.9 in
Length 15.4 in
Weight15 lbs
Width11.2 in
  • casters: 75 mm vs. 35 mm
  • Angle: 10°
  • Ports: ACMI, Wolf, Storz, Olympus
  • amp: 300W Xenon, Short arc
  • Wattage: 300 Watts
  • Color Temperature: 5500° - 6000°K
