Datex Ohmeda - Aestiva/5 Pendant
by Datex Ohmeda
The GE Aestiva/5 Pendant is both powerful and flexible.
The GE Aestiva/5 Pendant is a SmartVent ventilator that provides many features normally seen only in critical care ventilators. The machine can be used to accurately and easily deliver anesthetic gases at low flows. The Aestiva/5 Pendant also features a new, compact design, allowing greater access to patients while keeping controls within comfortable reach and removing clutter from the floor. A wide variety of configurations and accessory options enable a facility to "customize" the Aestiva/5 Pendant to meet patients' and clinicians' needs.
The Aestiva/5 Pendant is available for ceiling mount with a pendant base or a trolley base. Select a left or right handed design and an optional lifting device for columns without vertical movement. The mounting interface is compatible with ceiling columns manufactured by Kreuzer, Dräger and Heraeus.
Invalid Date
Internal workings prnciple
Datex ohemeda astiva5 service manual
  • Superior ventilation
  • Volume Mode, Pressure Control Mode, Pressure Support (PSVPro), Synchronized Intermittent Mandatory Ventilation (SIMV), electronic PEEP
  • Tidal volume compensation
  • One motion from mechanical to manual mode
  • Two key presses to total standby: end case
  • Cardiac bypass case mode
  • Open systems architecture
  • Lower overall height
  • User configurable drawers/shelving
  • Innovative patient breathing system
Height46.6 in Pendant base
GasesAir, Carbon Dioxide, Nitrous Oxide, Oxygen
Length 31.6 in Pendant base
Vaporizers (Max)Three
Weight290 lbs Pendant base
Vaporizer TypeElectronic control
Vent ModesVolume Control Pressure Control Synchronized Intermittent Mandatory Ventilation (SIMV) – (optional) Pressure Support (PSVPro) with Apnea Backup ventilation – (optional)
Width27.2 in Pendant base
