GE HealthCare - Revolution CT
by GE HealthCare
The Revolution CT provides uncompromised image quality and clinical capabilities through the convergence of coverage, spatial and temporal resolution.
Revolution CT has the ability to explore inside the human body non-invasively. It is the CT designed to help deliver revolutionary and differentiated capabilities across all clinical areas.
-Jasmine1929
Fri May 30 2025
Database not found
Hello Team,
Please I need urgent help.
My GE  REVOLUTION ACT 32 SLICE work station (AW) is not displaying any images, an error message “database not found “ keeps popping up.
What should I do please? I need help
Equipment: GE CT Machine
-tsnider
Wed Dec 21 2016
Axial Scanning
Is anyone scanning in Axial Mode? We are doing so at my place and the most challenging issue we have met is the placement of the "cut lines" to avoid the lower portion of the heart. Anyone else?
[list]      [*] New generator to support ultra fast kV switching.  [*] Best effective temporal resolution enabled by 0.28-second rotation speed combined with intelligent motion correction for excellent cardiac imaging at any heart rate.    [*] With the industrys fastest scintillator, the Gemstone Clarity Detector enables high definition imaging and ultra fast kV switching.    [*] Miniaturized detector modules are designed to reduce electronic noise by 25% which may improve image quality and reduce artifacts in low signal conditions, as may be encountered in large patients.          [*] Unique focally aligned detector design to overcome limitations such as cone beam artifacts associated with wide coverage.           [*] Proprietary 3D Collimator ensures IV contrast uniformity and minimizes scatter and beam hardening artifacts associated with wide coverage systems  it reduces scatter to primary ratio by more than 50% compared to a 160 mm system with a 1D post patient collimator.          [*] Whisper Drive system to reduce audible noise during gantry rotations by more than 50%. Future proof platform tested to support 0.2 sec/rotation, 70 g of force, and ultra fast kV switching. [*] Contactless slip ring to transfer data to and from the rotating side of the gantry to the stationary side through RF technology at 40 Gbps. Induction based, brushless slip ring to reliably transfer high voltage power.          [/list]
