CME - BodyGuard 323
Enter a new era in infusion management with the BodyGuard 323 infusion pump.BodyGuard offers a comprehensive range of features designed to maximize safe, economic and simple administration of infusion.
The BodyGuard 323 offers six programs: Continuous, 25 Steps, TPN, Intermittent sinusoidal and PCA.
BodyGuard is light, compact & robust ensuring it can be used in a wide variety of treatment settings such as hospital, homecare, transport or emergency medicine.
This flexibility is further enhanced by the rechargeable, internal Li-Ion battery and amains charger.
A piston pump mechanism ensures unparalleled accuracy and linearity of infusion even at the lowest infusion rates to meet the standards of the most demanding specialties & indications.
BodyGuard constitutes a major advance in ambulatory and bed - side pump technology incorporating active & passive safety features which can be configured to fit local practice and locked to prevent change by unauthorized personnel.
These features include security access codes anti - bolus system, free - flow protection in all consumables, downloadable patient and event history, adjustable air - in - line detection BodyGuard software can be adjusted to user needs, including choice of language for information display, range of features and settings.
FORUMSView All (12)
1Reply4 years ago | Changing mode How do i change from continuous to intermittent? Reply |
1Reply4 years ago | user manual need a copy of the user manual pleaseReply |
0Replies5 years ago | RESTART PUMP ERROR Bodyguard 323 alarms "Restart Pump" but appears error code. I can not activate any function of it. Who knows about this problem, please show me how to solve the problem. Thank you and Best Regards,Reply |
- Multi-programs infusion pump
- Lightweight & Compact –the smallest, lightest bed-side pump in its class
- Pole-mountable mains or rechargeable Li-ion battery operated to allow patient ambulation
- Piston pump mechanism ensures superior accuracy and linearity of infusion even at low delivery rates
- Post-occlusion Bolus Reduction System prevents false bolus after occlusion
- Comprehensive range of pump accessories including a large display charger for infusion status visibility on the ward, portable & pole mounted locking reservoir covers and carry cases
Volume to be Infused | 0.1 to 9999 ml |
Height | 112 mm |
Length | 32 mm |
Flow Rate Range | 0.1 to 1200 ml/h |
Weight | 280 g without battery |
Flow Accuracy | 5 % |
Infusion Pump Type | Patient-Controlled Analgesic (PCA) |
KVO Range | 1 to 5 ml/h |
Width | 89 mm |
FDA AlertsView All
CME America Recalls BodyGuard Infusion Pump System Due to Risk...
