GE HealthCare - Senographe Care
by GE HealthCare
With careful attention to a women’s health, from low-dose imaging to an innovative, interactive approach to mamography, Senographe* Care helps you redefine the patient experience.Senographe Care is durable and reliable. But we also designed it to deliver consistently outstanding image quality, so you can perform a wide variety of breast procedures in settings from in-office to mobile screening.
[list] [*] Six contrasts levels. Your images the way you like them. [*] Breasts differ, and so do clinicians’ viewing preferences. eContrast lets you improve structure visibility for almost any breast type, including implants and stereo images. [*] You can choose among six contrast levels, the setting that optimizes your visual comfort and diagnostic performance. And that’s not all – eContrast improves the image on spot views because the display is optimized for the region under the paddle. [*] Efficient imaging at low dose [*] An independent conversion detector with a Cesium-Iodide (CsI) scintillator on an amorphous Silicon (a-Si) flat-panel array results in a high DQE (70?) for efficient imaging at low dose [*] Repeatable image quality at optimized radiation dose [*] A dual-track X-ray tube (Mo/Rh) delivers an optimal X-ray spectrum to penetrate the breast based on breast density and compressed breast thickness. Automatic Optimization of [*] Parameters (AOP) helps you identify the densest breast regions. It automatically selects the appropriate anode, filter, kV and mAs, ensuring repeatable image quality at optimized radiation dose. [/list]
