BC Group - ESU-2400H
by BC Group
ESU Analyzer for Complex Waveforms
The ESU-2400H offers an unprecedented buffer depth of over 16 million samples. This allows for ultra-stable measurements of ESU Generator output waveforms and provides future-proofing for new generator outputs modes such as multiple pulsed waveforms.
-MedWrench MM
10 years ago
ForceTriad PM Procedure Using ESU-2400 Autosequence
VIDEOS
[list]  [*] The Industrys Most Comprehensive and Most Accurate Full-Featured Analyzer  [*] Measure Advanced Generator Outputs with Pulsed RF at Up to 3 Different Amplitudes  [*] Up to 16 million samples  [*] 1% Measurement Accuracy  [*] Based Upon Years of Collaborative Work with Leading Electrosurgery Industry Manufacturers  [*] Industry Standard RF Current Measurement  [*] DFATM Technology Ultra High Speed Digitization of The Complex RF Waveform  [*] Compatible with The Latest ESU Generator Platforms by The Major ESU Manufacturers  [*] Continuous & Pulsed Output Waveform Compatible  [*] Embedded Real-Time Operating System with 0.25 VGA Color Touch Screen Display  [*] Displays Up to 15 Different Measurement Parameters with User Selectable and Definable Screens  [*] Internal Precision Test Loads From 0 Ω to 6400 Ω in 1 Ω Increments  [*] External Test Load Compatibility  [*] Automated Power Load Curves with Multiple Power Settings Per Load Setting  [*] Automated User-Definable Testing Sequences  [*] Print test Reports to PDF format or USB Printer  [*] USB (3), RS232, and Ethernet CommunicationsPorts  [*] External Keyboard and Mouse Compatible Via Dedicated Ports  [*] Automatic or Manual Activation of ESU Generator During Power Load Curve Tests  [*] Remote Communications Capability withESU Generators  [*] 100% Compatible with Covidien/Valleylab Force Triad & Ligasure Generators, Conmed System 5000 Generators, and All Legacy Generators by Other Manufacturers  [*] REM/ARM/CQM Testing Via 500 Ω Adjustable Load in 1 Ω Increments  [*] RF Leakage Current Measurement  [*] Capture, Store, Print RF Waveform  [/list]
Height22.5 cm
Power Requirements100-240 VAC
Weight31 lbs
Analyzer/Simulator TypeESU
Current Range2 to 700 mAh
Voltage Range0.2 to 70 mAh
NEWSView All
NEW ESU-2400 Series Autosequence Available for Covidien FX8
Testing with the ESU-2400 and ESU-2400H just got easier!
