BC Group - USP-100SP
by BC Group
Ultrasound Wattmeter - Digital - 200 mW Resolution
The BC Biomedical USP-100SP Ultrasound Wattmeter is a precision instrument designed to measure the ultrasound power output of diagnostic and therapeutic transducers up to 30 watts. Ideal for biomedical engineers, clinical technicians, and ultrasound service professionals, the USP-100SP ensures accurate and reliable ultrasound power measurement using the radiant force method.
The system uses a positioning clamp to hold the transducer in de-gassed water above a conical target. As ultrasonic energy passes through the water, it reflects off the target and is absorbed by the rubber lining. The radiant power is directly proportional to the downward force (weight) on the target, which is measured by an internal electromechanical load cell. This advanced feedback system delivers a digital readout in either watts or grams of force, selectable via front-panel pushbuttons. (Generated by AI)
2RepliesThu Nov 12 2020 | Model Question Is the USP-100A the Same device as the USP-100SP?Reply |
Measurement range up to 30 watts
Dual measurement units (watts or grams)
±50 milliwatt display resolution
Includes 120 VAC to 12 VDC 400 mA adapter (use only the supplied adapter to avoid damage) (Generated by AI)
| Height | 8.5 in |
| Length | 12 in |
| Weight | 11 lbs |
| Analyzer/Simulator Type | Ultrasound |
| Width | 8.75 in |
