BC Group - USP-50SP
Ultrasound Wattermeter - Digital/Portable - 50 mW Resolution
The USP-50SP is designed to measure the ultrasound power output of diagnostic or therapeutic transducers up to 30 watts. The water tank requires only one pint of de-gassed distilled water. If de-gassed water is not available, use distilled water. The principle of measurement is the radiant force method
1Reply7 years ago | usp-50sp ultrasound wattmeter I would like to know the actual acceptable therapeutic readings on the wattmeter during the testing of an ultrasound units. How do I know that US unit is transmitting therapeutic levels.Reply |
- Digital Reading
- 0 to 30 Watts Range
- ± 3% + One Count Accuracy
- 2.5 Second Integration
- 0.05 Watt Display Sensitivity
Height | 7 in |
Length | 10.5 in |
Power Requirements | 120 VAC |
Weight | 10 lbs |
Analyzer/Simulator Type | Ultrasound |
Width | 8.5 in |
