BC Group - USP-50SP
by BC Group
Ultrasound Wattermeter - Digital/Portable - 50 mW Resolution
The BC Biomedical USP-50SP is a precision ultrasound wattmeter designed to measure the ultrasonic power output of diagnostic and therapeutic ultrasound transducers up to 30 watts. Ideal for biomedical engineers, clinical technicians, and medical device service professionals, the USP-50SP uses the radiant force method to deliver highly accurate, repeatable measurements for ultrasound system calibration and compliance testing.
The USP-50SP system features a compact water tank that requires only one pint of de-gassed distilled water for optimal measurement performance. If de-gassed water is unavailable, distilled water can be used as an alternative. The system is designed to provide dependable ultrasound power verification while minimizing setup time and resource use.
With its combination of measurement precision, efficiency, and ease of use, the USP-50SP is a go-to solution for preventive maintenance, performance testing, and regulatory compliance in hospitals, clinics, and biomedical labs. (Generated by AI)
-usp -50sp ultra sound watt meter
Wed Apr 12 2017
usp-50sp ultrasound wattmeter
I would like to know the actual acceptable therapeutic readings on the wattmeter during the testing of an ultrasound units. How do I know that US unit is transmitting therapeutic levels.Reply
[list]        [*] Digital Reading        [*]0 to 30 Watts Range        [*]± 3% + One Count Accuracy        [*]2.5 Second Integration        [*]0.05 Watt Display Sensitivity        [/list]
Height7 in
Length 10.5 in
Power Requirements120 VAC
Weight10 lbs
Analyzer/Simulator TypeUltrasound
Width8.5 in
