BC Group - AMM-15
by BC Group
Dew Point Meter
The AMM-15 Portable Dew Point Meter is a high-precision diagnostic tool engineered to monitor the performance of drying systems across medical, biomedical, industrial, and commercial settings. Designed for use with compressed air, nitrogen, and other inert gases, the AMM-15 is essential for ensuring system integrity and maintaining optimal operating conditions.
Utilizing advanced microprocessor circuitry and a high-accuracy HC-610 water vapor sensor, the AMM-15 converts voltage outputs into precise dew or frost point temperature readings using psychrometric equations. The integrated temperature sensor enhances accuracy, making it a reliable tool for professionals demanding real-time, lab-grade data. (Generated by AI)
  • Measures true pressure dew point up to 120 PSIG and 185°F
  • Optional heat sink tubing for sampling systems up to 550°F
  • Rugged, handheld ABS plastic enclosure for field durability
  • Quick-disconnect tubing couplings and internal sensor manifold for easy setup
  • Compatible with vacuum pumps for sampling from low-pressure or ambient systems
  • Ideal for compressed air quality testing and medical gas analysis (Generated by AI)
Height8.25 in
Length 4 in
Weight2 lbs
Analyzer/Simulator TypeFlow Meter
Width1.6 in
