GE HealthCare - Brivo XR385
by GE HealthCare
The Brivo XR385 is a general-purpose digital radiographic system designed for use in radiology departments that need to perform basic x-ray imaging, such as in ambulatory clinics. It allows hospitals to make the transition to digital with a basic X-ray system that is based on the same technology platform as that used on GE’s advanced X-ray systems. The Brivo XR385 is designed to handle radiographic applications using a single detector, high frequency generator and integrated table to provide flexibility for wallstand and tabletop applications.
1ReplyTue Nov 12 2024 | Time & Date How exactly do I change the date and time on this system? Reply |
3RepliesMon May 10 2021 | Artifact Hello, first timer on MedWrench here, I'm having an artifact unlike anything I've ever seen It's not a ring it looks like a path of higher density (water phantom) It resembles a beam hardening artifact but there's nothing in between the tube and the detectors... Reply |
0RepliesSat May 04 2019 | Reject Analysis How do you pull up the 'reject images on the XR385 machine?Reply |
[list] [*] Portable digital radiographic flat panel detector made of non-tiled amorphous silicon [*] Integrated floor mounted x-ray tube [*] Mechanical linkage between the tube stand and the table detector housing supports auto tracking of detector [*] Fast preview image with the fully processed image in less than 15 second [*] Post-acquisition processing for multiple “looks” from single exposure [*] Automated and customizable image transfer and printing [*] DICOM 3.0 and IHE compliant [*] iLinq* remote system diagnostic service support is available through the GE Online [*] Center and does not require on-site service personnel [*] Multi-resolution image processing for enhancement of detail [*] Tissue Equalization algorithm used to enhance contrast in over-penetrated and under-penetrated areas within the image [*] Intelligent Collimation Edge Detector (ICED) algorithm that automates image shuttering and cropping [*] Smart Windowing – automated, image based, and technique-independent method of determining brightness and contrast for image display [/list]
