Hillrom - 2000C
by Hillrom
Infant Warmer
[list] [*] Storing, Multi-Position Warmer/ Lighting Module [*]Full-Time Servo-Control to with in.5º C of set point. [*]High & Low Temperature Alarms, High Temperature Shut-off [*]Automatic Pre-Warm Function, Electronic Stopwatch with Apgar Timer [*]Dual-Yoke Gas Cylinder Manifold, Electronic Low Tank Pressure Alarm [*]High-Pressure Pipeline Oxygen , Supply Hose [*]Automatic Pipeline/Cylinder Supply Crossover Built-In Flowmeter, [*]Built-In Airway Pressure Manometer with Safety Pop-Off Valve, [*]Venturi-Operated Suction with Gauge and Mucus Trap [/list]
| Height | 70 in |
| Length | 39 in |
| Weight | 250 lbs |
| Width | 29 in |
