GE HealthCare - OEC Fluorostar 7900
by GE HealthCare
Mobile C-Arm
High performance in a cost-effective digital mobile imaging system. GE Healthcare continues its technical leadership in fluoroscopic imaging with the OEC Fluorostar 7900. This system provides imaging in multiple applications and versatile clinical environments. The Fluorstar 7900 provides 1K x 1K high-resolution imaging for multiple applications in a wide variety of clinical environments. Not available for U.S. market.
1ReplyWed May 13 2026 | #10018 ?? Fluorostar 7900, SW 03.01.02 Errors: - #10045 Slit collimator LEFT - #10018 COM2 - Cropped fluoroscopy image Fixed: - #10045 ? P1 potentiometer faulty - Replaced Collimator from donor - Self-test all axes green - Iris MAG-0/1/2 calibrated Still failing: - Cropped image - #10018 keeps returning Equipment: Oec fluro star 7900 Reply |
0RepliesFri Oct 17 2025 | Errors #10064 Hello how can be solved "Generator error STM line could not be reset" error code#10064 Reply |
2RepliesTue Jul 29 2025 | Help needed with TOUCH SCREEN Hi! Got problem with LEFT touch screen. It was failing calibration (the RIGHT ONE was OK): at the start it didn't recognize TOP LEFT corner. Started registering touches only somewhere near the BOTTOM RIGHT side. Thought resistive sensor is bad. Bought a brand new. Replaced. Problem still persists. One thing I should mention: even before replacing after and before replacing OLD SENSOR the problem was in registering touches. After RIGHT SIDE CALIBRATION when you Touch the TOP LEFT CORNER it got registered - corresponding message appeared that it is the right side. But when I try to actual register coordinates it does it wrong. Is there any ideas how to fix it? Reply |
| Maximum Focal Spot | 1.5 mm /.5mm |
| X-ray Generator Power Rating | 2.2 Kw |
