Prestige Autoclaves - 2100
by Prestige Autoclaves
The 2100 Classic water distillation unit takes regular tap water and transforms it into 99&#037 pure water.
The Prestige Classic 2100 is one of the world’s largest selling automatic autoclaves. Sold in 80 countries, it has gained an enviable reputation for reliability, durability and quality.
[list]  [*] Simple one step operation starts the automatic cycle  [*] Light sequence indicators show 'Power to Unit' - 'Cycle in Progress' -  'Sterilization in Progress' - 'Cycle is Successful' or 'Cycle has Failed'  [*] Interlock system prevents the lid from being removed whilst pressure remains in the vessel  [*] Two stage 'over pressure' protection system incorporating a calibrated Pressure  [*]Release Valve and a Gasket Offset Device  [*] Extended life 'green' gasket lasts in excess of 750 cycles  [*] Electronic detectors turn off the power if there is insufficient water  [*] Thermal fuse (all models) and double pole fuses (not 120v models) protect against overheating and electrical faults  [*] 'TST' indicator strips provide independent verification that the correct combination of temperature, steam and time has been achieved for successful sterilization  [*] For assurance of quality, each autoclave is computer tested and issued with a unique  [*] Performance Test Certificate showing that the parameters for successful sterilization are met  [*] Compact and Portable  [/list]
Chamber Volume9 L
OrientationBenchtop
Weight11.5 lbs
