ASP - Sterrad NX
Designed with the Next Generation technology, the STERRAD NX System is ASP's compact size sterilizer ideal for use anywhere in the hospital.
FORUMSView All (19)
2Replies4 months ago | NO SIGNAL ISSUE HI When I turn on the unit, a message "No signal" is displayed on the touch screen, then the screen turns off even though the device is running, meaning the power is on. I hope to know what caused the problem. Thank youReply |
3Replies4 months ago | Cancel Stage : Chamber Pumpdown 1, 2 Hi, my unit is having problem when running. Cycle will cancel during chamber pumpdown, either with load or no load. During diagnostic test, all test passed. Could you please advise what could cause this error and how to solve this issue? Thank you.Reply |
2Replies6 months ago | STERRAD Nx issue hiii When I turn on the unit, a message "No signal" is displayed on the touch screen, then the screen turns off even though the device is running, meaning the power is on. Thanks in advance for any help. I hope to know what caused the problem. Thank you Reply |
- Two tiered 30 liter chamber and two cycle options for increased productivity
- 28-minute Standard cycle for most surgical instruments
- 38-minute Advanced cycle for single-channel flexible endoscopes
- Space-efficient STERRAD NX System can be easily cart-mounted and moved where needed
- Provides terminally sterile, packaged instruments thereby eliminating the need to compromise with liquid biocides
Orientation | Benchtop |
Height | 84.3 cm |
Weight | 125 kg |
