Beckman Coulter - MD Series
by Beckman Coulter
Designed for Compact Spaces Perform
The Coulter MD Series Hematology Systems is a 16-parameter CBC and differential on only 12uL of whole blood - STAT - wherever testing needs arise. In the lab- OR- ER or ICU - there's a COULTER MD SERIES instrument that's a perfect fit. Simple to Learn Disk-Based Operation Automatic start-up and system checks- with easy-to-follow operator prompts- make the MD SERIES the easiest COULTER instruments to learn and operate. Easier Regulatory Compliance Control and calibration disks automatically load and check control and calibrator values- lot numbers and expiration dates. You also get access to Coulter's complete quality assurance program.         No Routine Maintenance Unique sample aspiration system - no blood sampling valve or pinch valves to maintain. Accurate Results and Complete Flagging System Triplicate counting ensures accurate results for confidence and improved patient care. Complete system of flags identifies samples needing review - eliminates time sorting abnormals.
[list]        [*] Easy-to-use touchpad        [*] Daily QC values are automatically logged and plotted        [*] Compact- Bench Top Design Saves Space LCD displays easy-to-follow operator prompts and results        [*] Accurate Results and Complete System of Abnormal Flags Coulter's exclusive triplicate counting process ensure accuracy.        [*] Proven Coulter Histogram Differential technology.        Whole blood sample requires no predilution time or predilution vial costs.        [/list]
