Siemens - Arcadis Avantic
by Siemens
Mobile C-Arm
As a multipurpose high-end mobile C-arm, ARCADIS Avantic exceeds expectations. It combines a 33 cm (13) II (image intensifier), with the high output of a 20 kW generator, a continuous digital 1K2 imaging chain, and dynamic recording at a maximum frame rate of 30 f/s in DCM (Digital Cine Mode). Virtually all DICOM functions are supported as well.
1Replya month ago | Service Error 5604 Equipment: Siemens - Arcadis Avantic Reply |
2Replies7 months ago | c arch siemens arcadis avantic Hello, i need to know after how many years i have to change the generator tube of arcadis avant c arch from siemens. The machine is from 2008 and the tube was never changed. Its because i want to buy a second hand one and dont know if i should ask those things and not find myself in the position that i need to change the tube after short time of use. thanks a lot Reply |
1Reply9 months ago | Avantic dose rate adjustement failing Hi, Just wondering if anyone can explain why the dose rate is failing after the 3rd test (zoom 1, lower)? It passes the first 2 ok (lower and upper), but just times out when calculating the 3rd (zoom 1, lower). I'm thinking the iris/camera may be the issue; what do you think ? Many thanksReply |
Maximum Focal Spot | 0.5 mm |
X-ray Generator Power Rating | 25 Kw |
