Philips - Heartstart FR2
by Philips
Defibrillator
The HeartStart FR2+ has come to be a trusted tool of professional responders and designated response teams in the work place and public settings. Its clean, uncluttered design is optimized for fast, efficient operation and rapid delivery of life-saving therapy. Commands are clear, streamlined, confident, and concise: ideal for responders who are trained, drilled, and ready to save a life now.                        The HeartStart FR2+ can be configured to allow ALS responders to switch to a manual mode, giving them more decision-making control. Defibrillator pad adapters enable the pads to remain on the patient when transferring to many popular ALS manual defibrillators from Philips and other manufacturers.                        The product is extremely easy to use. Its design is based on years of research, refinement by Philips human factors experts and user testing with the full range of responders from healthcare professionals to lay people. In fact, hundreds of thousands of citizens are already trained and ready to save a life with the FR2+.                        Because of its ruggedness and ability to stand up to temperature extremes and wet conditions, the HeartStart FR2+ is the right choice for harsh, outdoor, or mobile use. It combines natural sounding voice instructions that are loud and clear, with text prompts on a large, bright back-lit display. This makes it ideal if you anticipate its use in noisy or poorly lit settings. And at just 4.7 pounds, it's incredibly small and light-weight so it won't weigh you down.                        The HeartStart FR2+ can treat patients of any age. When equipped with special infant/child defibrillator pads that reduce the energy of the FR2+'s shock, you can safely treat a child or infant in cardiac arrest.
-jason@elitebiomedical
3 years ago
No Sound
Anyone out there know what causes the sound/speaker to stop working? Swapped out the speaker and still no sound. Thanks in advance.Reply
-Nana
8 years ago
Heartstart FR2
Dear sir,
Could you help me get the battery for Philips Heartstart FR2 battery to purchase?
Thanks
SERVICE COMPANIESView All Defibrillator Companies
  • Long life battery
  • Minimum 300 shocks when new. Shelf life before installation and standby life after installation typically 5 years each
  • Rechargeable training battery
  • Backlit display
  • Improves the quality of ECG and text prompts in conditions of direct sunlight and darkness
  • Selftest and status indicator
  • Monitors readiness and clearly displays whether or not the device is operational
  • Easy and flexible configuration
  • Allows extensive configuration possibilities, including treatment protocol in accordance with new ERC or AHA guidelines
  • Manual override
