Siemens - Siremobil Compact L
by Siemens
Mobile C-Arm
Whether radiography, continuous fluoroscopy, or digital subtraction angiography, SIREMOBIL Compact L supports the entire spectrum of X-ray-based applications in the operating room.SIREMOBIL Compact L stands for clinical versatility, excellent image quality with low dose, optimized workflow, and cost efficiency.
FORUMSView All (87)
-Chaovalit
2 months ago
Error 4021
Hello, I got error 4021 from Siremobil Compact L with Memoskop CX, The text appear on monitors. The memoskop function CTRL+T, CTRL+U work with generator connected. I have checked the X10 'main umbilitcal cable' connection pins for damage/bent over, and none of the pins are pushed-in, a couple of pins are partly-in, this is normal. I have checked the cable wires between the X10 & Memoskop in case a wire is broken. I tried to Memoskop, Technical setup, menu "Diagnostics" - "Erase Harddisk" but doesn’t has “Diagnostics” menu, Please advice. Best Regards, Chao.Reply
-Rood
3 months ago
Error 7400 $ 8000
Those two error showed up after starting the machine
Equipment: Siemens - Siremobil Compact L
-Kanna
7 months ago
Error 8000 and 2005 coming
error 8000 and 2005 is coming while turn on the machine
SERVICE COMPANIESView All Mobile C-Arm Companies
  • Optimized Clinical Workflow and Connectivity
  • High Quality Imaging
  • Powerful Performance of 1,4 kW
  • User-Friendly Operation
  • Clinical Versatility
  • Dose Savings
  • High power output of 1,4 kW
  • Virtually unlimited fluoro time - over 50 minutes
  • Tube currents of up to 8.9 mA for fluoro, up to 12 mA for DR
  • 7 or new 9 light-weight image intensifier
  • Storage capacity from 200 up to 5000 images
Maximum Focal Spot0.6 mm
X-ray Generator Power Rating1.4 Kw
