HP - PageWriter 100
The PageWriter 100 EKG provides printed traces which use a continuous feed, high-res printer. What does this mean for you? Well, it means no more cutting electrocardiograms because reports from the PageWriter 100 fit on a standard page. Patient data records are easily identifiable with our alphanumeric keyboard.
0Replies9 years ago | Can not print Dear all, I have ECG PageWriter 100. Error: "Check battery" display on sscreen whenever.ECG signal is normal but I can not print it. After press button "Copy"(=Print), the error "Check battery" is appeared on screen. My purpose = print it. I checked battery OK, replaced new battery but the problem is not fixed. Sensor is OK. Motor is OK. What should I do? Please. Thank in advance. Regards, Thuong Reply |
- 12-lead ECG
- Lead acid battery (rechargeable)
- Records at 5, 10, 25, and 50 mm per second
